1967 top of front shocks look like what??? - NCRS Discussion Boards
  • Keith G.
    • October 30, 2006
    • 316
    What does the top of a front shock look like, squared off, normal bolt or a screw driver slot????
    • January 31, 1988
    • 43193
    Re: 1967 top of front shocks look like what???
    Keith------
    Assuming that you are talking about the top of the shock rod, it is round with flats on either side for the installation of a 1/4" wrench. This same configuration was used for all other Delco shocks of the period that I know of.
      • 15573
      I will make the same assUmption as Joe L. That shape is known as a D or double D socket. There are several different sizes as that shape is used in other places than shock absorbers. The link is just one (the most common size) example.
      • Gary B.
        • January 31, 1997
        • 6976
        Terry,
        I never knew there was such a socket as that. You taught me something today. A good day.
        Gary
          • 15573
          Originally posted by Gary Beaupre (28818)
          Terry,
          Gary
          I am happy to help Gary
          I thought about putting a link to the Snap-on version, but I thought I would go more working class today. :-)
          On a more serious note, there are many versions available from a variety of sources.
          • Tim G.
            • February 28, 1990
            • 1358
            I too never knew such a tool existed, Terry. I need to pick one of those up.
            Thanks.
            • Dan P.
              • November 30, 1990
              • 683
              The top of the stud was square so a 1/4 wrench would fit over it . The very top of the stud was concave because they rolled the threads . Through out the years Delco used differnat widths for the flat spot on the top. if you want pictures let me know and i will post them.
              • Dick W.
                • 10483
                https://www.google.com/search?sxsrf=...4dUDCAc&uact=5
                The devil made me post this
                Dick Whittington
                • Dan P.
                  • November 30, 1990
                  • 683
                  I am still making payments Cool old tool box.
                  • Ray G.
                    • May 31, 1986
                    • 1187
                    universal shock top wrench
                    I hope you dance
                    • Dick W.
                      • 10483
                      I like the socket. Quick zap from the impact and the nut is off.
                      Dick Whittington
                      • Timothy B.
                        • April 30, 1983
                        • 5177
                        I never knew that socket existed either.
                        How many of us can remember holding that stud with a 1/4" open end wrench and the nut was hard to come off so you had to wrench and cuss the whole way. Worse, it was cold outside and your fingers were numb then you dropped the nut or something else. I miss the seventies..:-)
                        • Ray G.
                          • May 31, 1986
                          • 1187
                          Dick;
                          Borrowed this image from Dan Patch.
                          First we would clean the threads and then secure the shock shaft with the vise grip, at the enlarged area just below the threads,
                          and then remove the nut.
                          my .02
                          Ray
                          I hope you dance
