67 front sway bar question - NCRS Discussion Boards
  • Ralph P.
    • February 1, 1990
    • 253
    Can someone confirm the dimensions of the original washers holding the rubber bushings ? I seem to have 2 different sizes . Actually a photo and dimensions would be great. I'm talking of those on the links, not the actual attachment to the frame.
    THANKS
    • 43273
    Re: 67 front sway bar question
    THANKS
    Ralph------
    There were a plethora of part numbers for these retainers over the years. However, the originals were 1.25" OD and 0.069" in material thickness (i.e. the thickness of the material they were stamped from). Later GM replacements were 1.40" OD and .107" material thickness.
    Below are photos of originals and later GM replacements.
    Original retainers, front and rear
    GM replacement on left and original GM on right
    Thickness comparison between replacement and original
    By the way, I expect that, functionally, the replacements are superior to the originals. You don't think that GM went to a larger OD and thicker material because the original-spec retainers worked just as well, do you?
    • Ralph P.
      • February 1, 1990
      • 253
      Thanks so much, Joe !
      Exactly what I need....
