69 drivers side carpeting - NCRS Discussion Boards
  • Mark B.
    • March 8, 2017
    • 119
    I purchased a set of Al knock carpeting for my interior. In question, As iIlaid the carpet for fitment and where I was going to trim, I noticed that the foot pad by the high beam switch will be very close to the pad as I make the whole. The issue I am concerned about is that when I put the kick panel back, the foot pad is almost behind the kick panel and prevents the kick panel to be installed. Did anyone have any issues and do you have any pictures.
    Should there be a footpad near the high beam switch?
    Mark
    • 43273
    Re: 69 drivers side carpeting
    Mark
    Mark------
    Yes, there was a footpad for the high beam switch. I can tell you this much: even the original installation was "dicey". I was never satisfied with the fit of the carpet/footpad in this area on my original owner 1969.
    • Mark B.
      • March 8, 2017
      • 119
      Joe, the majority of the footpad goes behind the kick panel and doesn't fit well. Was it possible that it didn't have a footpad?
      Mark My cell 631 241-9507
      • Reba W.
        • 938
        Only very late 1969s had the dimmer pad, and it was unlike what was added in 1970. I doubt that any repro carpet will have it correct. There is a photo on p. 22 of the latest JG.
        • Jeffrey S.
          • May 31, 1988
          • 1898
          Mark,
          What is the build date of your car? Early 69's did not have a foot pad. My Oct '68 car is one. The Judging Guide says that until Sep of '69, most cars did not have pad.
          Joe, wasn't your car built around that time?
          Jeff
          Reba,
          Your post was 2 minutes before I entered "POST"
          Jeff
            • 43273
            Originally posted by Jeffrey Salz (13182)
            Mark,
            Jeff
            Reba,
            Jeff
            Jeff------
            My car was built mid-September, 1969.
            • Jeffrey S.
              • May 31, 1988
              • 1898
              Joe,
              That's what I thought.
              Jeff
              • Mark B.
                • March 8, 2017
                • 119
                My build date is 11/25 car. So i guess i had the footpad.
                Mark
