65 Fan Clutch - NCRS Discussion Boards
65 Fan Clutch
  • Bill B.
    • June 30, 1999
    • 182
    65 Fan Clutch
    Getting ready to install new Dewitts radiator on my 65 327/300 coupe. What is the best fan clutch I can install that would be local purchase from a parts store. I don't want to spend a lot of money on a original. Fan clutch hasn't worked for quite a while. Regardless of engine temp. it is always engaged. Thanks in advance.
    Bill B.
    • 43273
    • Bill B.
      • June 30, 1999
      • 182
      Re: 65 Fan Clutch
      Thank you,Joe. I was hoping you would respond.
        • 43273
        Re: 65 Fan Clutch
        Bill------
        One thing I should have mentioned is that it's quite unusual for a fan clutch to be "locked up" all the time. Usually, the failure mode is that the clutch will not "engage" and the engine consequently overheats in certain situations (like low speed or idling).
        • Bill B.
          • June 30, 1999
          • 182
          Re: 65 Fan Clutch
          Joe...With the engine cold and not started it is very hard to turn the fan. With the engine at operating temp after a long drive , I turn off the engine and the fan is as hard to turn. After the engine cools completely, no difference. Clutch has been on the motor since the late 80's so I"m thinking it's bad. Thanks for your reply.
          • Kent S.
            • February 1, 1993
            • 206
            Re: 65 Fan Clutch
            If it truly is "locked up", I'd just leave it on there - it would look correct and yet provide maximum cooling. For driving, many folks (including me) spend good money for a fan clutch eliminator from one of the vendors to accomplish the same thing.
            • Bill B.
              • June 30, 1999
              • 182
              Re: 65 Fan Clutch
              Kent...You're reasoning is why I have not replaced the clutch when I noticed the problem a couple of years ago. I figured it was getting cooling all the time so no worries. I'm replacing the radiator soon and figured it would be a good time to replace the clutch also. Thank you for your comment.
