water pump question 66 L79 - NCRS Discussion Boards
  • William P.
    Infrequent User
    • December 15, 2006
    • 12
    Can anyone please tell me what a water pump with casting number 3858826 or possibly 28 is used on. This pump is on my 1966 l79 engine that is being rebuilt.
    Thank you
  • John R.
    • November 1, 2005
    • 433
    Re: water pump question
    Are you sure it is not 3859326? That would be a correct casting for a '66 L79. Needs the 1/2 inch bypass and should be dated. Others can chime in....
      • 43290
      John and William-------
      Yes, the number must be 3859326. In fact, GM #3858826 was a backing plate for the right front brake for 1959-64 passenger cars and 63-64 Corvettes.
      The 3859326 is the correct pump for a 1966 L-79 with, as mentioned, a 1/2" NPT by-pass fitting.
      • William P.
        Infrequent User
        • December 15, 2006
        • 12
        Thank you for the replies. I will check the numbers again and let you know what I find.
          • 43290
          William------
          Casting numbers are notoriously difficult to decipher. "3", "5", "6", "8" and "9" are often confused.
          • William P.
            Infrequent User
            • December 15, 2006
            • 12
            Again thank you to everyone who replied. The 9 and the 3 were where the problem was so I used a large magnifying glass and have determined it is the correct pump.
