1968 C3 Front Air Dam - NCRS Discussion Boards
  • John D.
    Infrequent User
    • March 8, 2019
    • 4
    Hello All,
    I have a question regarding my 1968 C3. I have just installed a replacement lower front air dam on my car. The two middle mounting bolts are a black oxide. When originally installed were these bolts left black oxide or were they painted the body color. Thank you in advance for your help.
    John
  • Terry B.
    • August 31, 1999
    • 607
    Re: 1968 C3 Front Air Dam
    The bolts were left black oxide.
    Terry Buchanan
    Webmaster / Secretary - Heart of Ohio Chapter www.ncrs.org/hoo
    Corvettes Owned:
    1977 Coupe
    1968 Convertible 427/390 (L-36) Chapter Top Flight 2007, Regional Top Flight 2010, National Top Flight 2011
    2003 Electron Blue Coupe
    2019 Torch Red Grand Sport Coupe
    • John D.
      Infrequent User
      • March 8, 2019
      • 4
      Terry,
      Thank you I appreciate the info.
      John
        • 43259
        All----
        A small point but the bolts and nuts are black phosphate, not black oxide. Black oxide is a finish which is actually rarely used on original fasteners. Those fasteners which are done in black oxide are usually interior parts, not body or chassis parts.
        • Ron G.
          • December 1, 1984
          • 865
          My opinion based on my experience with original type cars is that the bolts, and nuts that attach the front air dam are gray phosphate.
          "SOLID LIFTERS MATTER"
            • 43259
            Ron------
            Yes, I use "black phosphate" as a generic term for any phosphate-finished fasteners. However, there are differences in "degree of blackness". The bolts and nuts in question are better described as gray phosphate. GM just uses the term "phosphate" to describe the finish.
