1964 Alternator - NCRS Discussion Boards
1964 Alternator
  • James C.
    • July 4, 2012
    • 81
    1964 Alternator
    Looking for some more advice - the alternator on my car (64) passed flight judging but they said the back should be turned (clocked) 180 degrees. When I checked my tech manual I think it is clocked correctly.
    Any advice would be appreciated.
    Jim
  • Jim D.
    • 2885
    • James C.
      • July 4, 2012
      • 81
      Re: 1964 Alternator
      Thanks Jim!! Appreciate the pic..
      Jim C.
      • Dan B.
        • July 13, 2011
        • 545
        Re: 1964 Alternator
        Good question and great answer. I know there are plenty more that need to be flipped 90*. It seems many have come from the rebuilders that way and people just assume it's correct. Thanks for that photo Jim.
          • 43281
          Re: 1964 Alternator
          Dan------
          GM used different part numbers for the various "clockings" of alternators otherwise identical. Rebuilders may not use the correct clocking for a particular part number.
          • Richard S.
            • February 1, 1984
            • 85
            Re: 1964 Alternator
            With an A/C car the alternator is on the drivers side, is it 180* compared to the no A/C?
            • Jim D.
              • 2885
              Re: 1964 Alternator
              Not sure about 64 but for 65 A/C and big block cars, the drivers side mounted alt. still has the gray plug at the 3 o'clock position.
              • Dan B.
                • July 13, 2011
                • 545
                Re: 1964 Alternator
                Dan------
                So, the same P/N alternator (eg. 1100668)ordered for a 64 Corvette from a GM dealer back in the day would have come clocked differently than one ordered for a 64 passenger car because they had different order numbers in the parts books? Very interesting, and makes sense. Thanks Joe.
                  • 43281
                  Re: 1964 Alternator
                  Dan------
                  Most likely, yes. However, a different part number would have resulted if there was some other difference in the alternators (e.g. amperage, etc.) even if they were clocked the same. Another example: sometimes alternators were used in PRODUCTION which were supplied to PRODUCTION with installed pulleys. Such alternators would have had a different part number than the exact same alternator supplied to PRODUCTION or SERVICE without an installed pulley. So, there were lots of reasons for different alternator part numbers and that's why there was such a plethora of alternator part numbers.
