Swivel head LED flashlight - NCRS Discussion Boards
  • Dennis C.
    • June 30, 2002
    • 884
    Re: Swivel head LED flashlight
    Originally posted by Scott Sinclair (2379)
    Dennis, That is so thoughtful of you, We are sure that Donna will be pleasantly surprised at Christmas.
    Someone has to do all the work in the garage.
    LOL
    • Michael J.
      • January 27, 2009
      • 7157
      Originally posted by Jeffrey Salz (13182)
      Again, thanks for the suggestions. Here's the one I like so far:
      https://www.amazon.com/ELMCHEE-Recha...s%2C175&sr=8-9
      I am VERY skeptical that it could have 12,000 lumins but even if it 1200 it's the brightest I've seen. Thanks again all.
      Jeff
      I like that one, I need to replace the one I have for camping. Could work in the garage too. Thanks!
      • Steven B.
        • June 30, 1982
        • 4002
        #18
        Jeff
        I gave my grandson this one for his treks in the NH woods a few months ago and it worked well in the woods, the garage and the shed at night.
        • Jeffrey S.
          • May 31, 1988
          • 1892
          #19
          Stephen,
          Thanks for the review. That's what I was hoping to hear. It will get ordered on Monday.
          Jeff
          • Dick W.
            • 10483
            #20
            Jeff
            As I have gotten older and blinder, I need a lot of light to see anything. I bought one of those head lamps some time back and love it.
            Dick Whittington
            • Steven B.
              • June 30, 1982
              • 4002
              #21
              I know what you mean Dick. I had to read this twice because I don't hear so good anymore.
                • 11679
                #22
                I have this one:
                https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
                and this one:
                I find the first one a bit more comfortable, the second is brighter. I have another that isn't comfortable at all.
                I have spent a lot of hours working on cars with the first one, and would prefer that one for cars given the amount of time and lighter weight. The second I have used quite a bit recently for hunting and other activities, and it does weigh a bit more which can get noticeable. It has two 3200mAh batteries, which are larger capacity but same size as the first headlamp.
                Buy both and play with them.
                Patrick
                • Dick W.
                  • 10483
                  #23
                  Originally posted by steven brohard (5759)
                  i know what you mean dick. I had to read this twice because i don't hear so good anymore.
                  lol!
                  Dick Whittington
                  • Jeffrey S.
                    • May 31, 1988
                    • 1892
                    #24
                    I have this one:
                    and this one:
                    Patrick
                    Patrick,
                    Thanks for the advise. I think that the one I posted is the one I will get. It has 5 lights, is adjustable, and claims to be brighter than the surface of the sun. Thanks all for you help.
                    Jeff
                      • 11679
                      #25
                      Patrick,
                      Jeff
                      The batteries with that one are only 1500 mAh. Think highly about replacing them with higher capacity batteries if you use it much.
                      • Jeffrey S.
                        • May 31, 1988
                        • 1892
                        #26
                        Patrick,
                        Thanks. I ordered a slightly different unit that purports to have even greater lumins (13,000), has 8 lights, and got 5 stars. It didn't say what the batteries mAh were but for my use, it is probably just fine. Thanks to everyone who helped me out.
                        https://www.amazon.com/Harmonic-Head...%2C176&sr=8-14
                        Jeff
                          • 11679
                          #27
                          Patrick,
                          Jeff
                          I bought this one just to check it out. It arrived yesterday.
                          Here are my thoughts:
                          1. It does not produce anywhere near 13000 lumens, no matter how you look at it.
                          2. If your head is a size Large or XL (hat size 7 1/2 or more) then forget it. This thing is small; far smaller than any others I own. It slides right up off my head when I put it on with the adjusters fully extended. I usually wear a L/XL or 7 1/2 to 7 5/8 hat size.
                          3. There are a lot of lights that take up a lot of space on the front. Having a single smaller light is my preference in regular use as more lights = more weight. However, overall the weight on this unit is not as bad as some.
                          I hope that helps some others.
                          I'm sending it back since it's too small for my head.
                          • Jeffrey S.
                            • May 31, 1988
                            • 1892
                            #28
                            Patrick,
                            1. As I said above, I highly doubt that it could produce 13,000 lumins but would surely be brighter than the cheap (as in free) HF unit.
                            2. My hat size is 7. Hopefully it will fit.
                            3. My thought was that since the lights are from 8 sources it would spread out the light more.
                            We'll see when I get it.
                            Jeff
                            • Gary C.
                              Administrator
                              • October 1, 1982
                              • 17775
                              #29
                              Found it's easier to try 'em on at Home Depot and Lowes before buying. Just sayin',
                              Gary
                              NCRS Texas Chapter
                              https://www.ncrstexas.org/
