front coil spring finish - NCRS Discussion Boards
  • Robert P.
    • October 19, 2019
    • 298
    Looking to freshen up my coil springs in my 66 roadster, should they be a natural cast iron color or another color
    thank you in advance Bob
  • Michael M.
    • January 31, 1993
    • 603
    Re: front coil spring finish
    The front springs are coated with a rust inhibitor and have a black appearance.
    • Brian M.
      • October 31, 1994
      • 119
      Any suggestions on how to achieve this black appearance?
      looking at some pervious posts on this subject, it seems there is a question as to whether the black rust inhibitor is indeed correct looking at my 65 springs, I do not see any evidence of a coating.
      Brian McIntyre
        • November 30, 1989
        • 11603
        I don't think it was black.
        I think they were shot peened and then coated, but think more of a thin Cosmolene than a black coating.
          • January 31, 1988
          • 43191
          Patrick------
          I agree.
          • David B.
            • February 29, 1980
            • 686
            Per Chev. Engineering print:
            "Spray or dip with Lucas Rustproof #635 compound or equivalent for rust prevention (mix 7 parts of water with 1 part rust proof compound)
            • Ron G.
              • November 30, 1984
              • 865
              Here is my 2 cents. Like the prior replies, I believe that they were natural cast steel. I would recommend that if you do leave them natural, put a protective oil on them to minimize rust such as Pre-Lube 6. No matter how well you store your car, corrosion is inevitable and you may have to repeat your efforts a couple times per year.
              "SOLID LIFTERS MATTER"
