Correct Vacuum Hose - NCRS Discussion Boards
Correct Vacuum Hose
  • Brian V.
    • January 19, 2019
    • 19
    Correct Vacuum Hose
    I have a 1972 No-AC, base 350/200hp/4-speed coupe.
    I'm looking to replace the vacuum hose that connects the manifold fitting to the vacuum filter and then to the vacuum check valve,
    I'm trying to source only that section of the vacuum system, yet all I am finding are complete vacuum hose kits for my year/model.
    Can anyone tell me the original/correct hose diameter for that section, and where I might find the correct style hose for this application?
    Any info is appreciated.
    Thanks!
  • Jeffrey S.
    • May 31, 1988
    • 1901
    Re: Correct Vacuum Hose
    The original hose going from the manifold fitting to the filter and from the filter to the check valve on the 72 that is being stored in my shop measures .4675" (using a cheap Harbor Freight digital caliper) or really 1/2" OD. There is a single raised rib on one side and a series of multiple raised ribs on the other. Hope this helps.
    Jeff
    • Brian V.
      • January 19, 2019
      • 19
      Absolutely helps Jeff! Thank you!
      Now to find some.
      • Larry M.
        • January 1, 1992
        • 2701
        Now to find some.
        I would call DR REBUILD first. Then perhaps David S and David Crane in California. Maybe also use a WTB ad in Driveline.
        Larry
        • Brian V.
          • January 19, 2019
          • 19
          Larry
          Thanks Larry. I am going to see if Dr Rebuild can help.
