901 engine coil - NCRS Discussion Boards
901 engine coil
  • Wally A.
    • May 31, 1979
    • 170
    901 engine coil
    OK i know either is correct,when it comes to judging, what difference would it be if i use a Delco 901 china coil,
    versus staying with a GM style coil, as far as points deductions. Mr. El Cheapo thanks for the input
  • Wally A.
    • May 31, 1979
    • 170
    Re: 901 engine coil
    to early in the morning, my typo error 091 coil
    • Louis R.
      • June 3, 2018
      • 8
      • Ed S.
        • August 6, 2014
        • 1377
        Re: 901 engine coil
        Louis, can you define "generic". Is that an overseas repro, an AC Delco from NAPA or...... what? What is the part # and where did you get it. Thanks.
        Ed
        • Louis R.
          • June 3, 2018
          • 8
          • Mike M.
            • May 31, 1974
            • 8400
            Re: 901 engine coil
            the chinese repos have a pair of stainless steel studs to attach the coil wires. easy for judges to spot. and they have the lifespan of a puppy pee pee flea. mike
            • Louis R.
              • June 3, 2018
              • 8
