Does anyone know the dimensions of the hex nut GM 3765425? I know it's 7/16-14, but I don't know the thickness or if the across the flats dimension is typical for 7/16 or if it's a light nut. The only place it appears in the '66 AIM is for the rear differential front mount. The repro bolt kit for that application that I purchased contains a distorted thread nut. And I'm suspicious that's not correct.
Gary
Gary
