Hose routing photos request - NCRS Discussion Boards
+ More Options
Posts
  • Larry M.
    • December 1, 1986
    • 541
    Can anyone with an untouched 1972 small block no AC car provide photos of the vacuum hose routing in the areas shown in the attached photos? After 48 years, such a car might be difficult to find. I've looked in the AIM and the 5th ed. 70-72 TIM, but the routing isn't clearly evident.
    The wiper door actuator and all three vacuum relays are out for restoration, and on their return, I'd like to route the hoses as correctly as possible.
    Thanks for any help,
    Larry
  • Jeffrey S.
    • May 31, 1988
    • 1902
    Re: Hose routing photos request
    Larry,
    I have an original owner, untouched '72, no A/C, in my shop and I can take some photos tomorrow. I will ost as soon as I can.
    Jeff
    • Larry M.
      • December 1, 1986
      • 541
      Thank you, Jeff.
      Larry
      • Brian M.
        • February 1, 1997
        • 1842
        Doesn't Dr. Rebuild have a clear routing road map of these lines?
        • Larry M.
          • December 1, 1986
          • 541
          Brian,
          Thanks; yes, he does, and I have it. It very clearly shows what hoses go to what ports on each item (relay, switch, actuator, etc).
          What it doesn't show, and what I'd like to find out, is the actual physical positioning of the hoses as they go through any clamps/brackets and around any components to get to their respective ports. I'd imagine that information can only be gleaned by looking at original, untouched examples (of which as time goes by there are fewer and fewer to compare).
          Larry
          Larry
            • 11698
            Larry,
            Did you look at the photos in my link shown in my signature?
            Patrick
            • Larry M.
              • December 1, 1986
              • 541
              Patrick,
              Yes, I did; thank you. Fantastic photos. Our car does not have the expansion tank in the area that yours does, so I'm not sure how the presence of one would affect the routing (if at all).
              Larry
              • Jeffrey S.
                • May 31, 1988
                • 1902
                Larry,
                Attached are the photos I promised. I hope these are helpful. The car was driven from 1972 when new until 1979 when it was parked in a damp garage. In 2010(?) I got the car running again and about 200 miles have been put on it since. It has been sitting in my shop now for over a year without driving. It has 56,000 miles on it. As you can see there is a good amount of rust everywhere.
                Jeff
                • Larry M.
                  • December 1, 1986
                  • 541
                  Jeff,
                  Thank you; these are perfect! In photo three, just to the left of center photo, is that a band of electrical tape wrapping the hoses together?
                  Larry
                    • 11698
                    Originally posted by Larry Maher (10731)
                    Patrick,
                    Larry
                    Larry,
                    You have an automatic transmission then, I assume?
                    PH
                    • Larry M.
                      • December 1, 1986
                      • 541
                      Patrick,
                      No; it's a 4-speed.
                      Larry
                      • Larry M.
                        • December 1, 1986
                        • 541
                        Copper radiator; LT-1.
                        • Jeffrey S.
                          • May 31, 1988
                          • 1902
                          Jeff,
                          Larry
                          Larry,
                          I would have to get a closer look when I am back in the shop Sunday. BTW - this car is an automatic if it matters.
                          Jeff
                          • James G.
                            • August 22, 2018
                            • 816
                            Jeff,
                            Larry
                            It's not electrical tape, the tape used appears like the base of the tape is woven (closer to how friction tape appears) with a thin black liner over the adhesive (liner is much MUCH thinner than electrical tape).
                            The car shown has the hoses routed just like my unrestored LATE 1971 LT1.
                            Maybe these will help you out as well...
                            James A Groome
                            1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
                            1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
                            My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
                            Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
                            • Larry M.
                              • December 1, 1986
                              • 541
                              James,
                              Thanks very much. Your tape info and photos are useful and appreciated.
                              Larry
