'72 door plunger swtich - NCRS Discussion Boards
  • Jerome P.
    • October 22, 2006
    • 607
    The plunger switch seams to not extend (spring out) out all the way when the door is fully opened. Thus the interior courtesy lights fail to come on. I can gently wiggle the plunger and/or gently pull on the plunger, and the lights come on. The next time the door is opened same thing no lights until I move the plunger.
    Opinion: obviously, I have a poor connection. Short of replacing the switch or checking the wire connect, is there any problem with spraying the unit with some CRC's - Lectra-Motive Electric Parts Spray Cleaner or similar to lubricate and clean the plunger and hopefully remedy my problem.
    Your thoughts.
    • 43272
    Re: '72 door plunger swtich
    Your thoughts.
    Jerome------
    There's no problem with doing what you suggest but I don't think it will solve the problem. More likely, the shaft of the switch has become slightly bent or distorted.
    • Jack C.
      • September 30, 1992
      • 1090
      I had the same issue. I used contact spray and it has been working ever since.
      Jack Corso
      1972 Elkhart Green LT-1 Coupe 43,200 miles
      Top Flight 1994, 2018 & 2021
