Rear crossmember sombrero mounts - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7018
    In a 2006 article by John Hinkley in the Corvette Enthusiast, he mentions the use of an anti-seize compound to facilitate installation of the rear crossmember on the sombrero mounts. Does anyone have a recommendation for what anti-seize to use that is compatible with rubber?
    Gary
    • 43219
    Re: Rear crossmember sombrero mounts
    Gary------
    All anti-seize compounds I know of contain petroleum compounds. So, theoretically, there is some potential incompatibility with rubber. However, I don't think it would be an issue, at least for as long as any of us, at this point, are going to be using these cars.
    • Dick W.
      • 10483
      Gary
      Neverseize
      Dick Whittington
      • Gary B.
        • February 1, 1997
        • 7018
        Dick,
        As in "Never-Seez 30840652 Regular Grade"?
        Gary
        • Gary B.
          • February 1, 1997
          • 7018
          Gary------
          Joe,
          Yes, petroleum-based compounds and rubber incompatibility was my concern.
          Gary
            • 15599
            Gary
            Try silicone grease. The lubricating kind works best, not the electrical insulating kind (called dielectric grease). I think the lubricating kind is commonly sold as Sil-glide.
              • 43219
              Terry-----
              That's actually exactly what I used.
              • Gary B.
                • February 1, 1997
                • 7018
                Thanks all.
                Gary
                • Jack J.
                  • July 31, 2000
                  • 640
                  Please correct me if I'm wrong, but aren't we talking about metal to metal contact and not rubber to metal contact. I don't understand how any petroleum grease product could possibly effect the rubber portion of the sombrero since it, (the grease), is used to facilitate ease of insertion and prevent rust buld-up between the two metal contact surfaces should the sombreros need to be changed out in the future which is probably unlikely.
                  • Gary B.
                    • February 1, 1997
                    • 7018
                    Jack,
                    The metal (quasi-hemisphere) sombrero that is part of the frame inserts into the mating rubber bushing of the removable crossmember. That junction is a bear to get apart during dis-assembly. And presumably also harder to re-assemble w/o a lubricant. So, no it is not metal to metal.
                    Gary
                      • 15668
                      The frame "pad" is steel and the cushion is rubber, so the interface is rubber/steel, and I agree that a thin film of silicone grease as mentioned above should be applied to both surfaces, which should keep them from seizing, and silicone based grease will not attack the rubber.
                      • Michael J.
                        • January 27, 2009
                        • 7121
                        And make sure you put them in right side up......
                        • Jack J.
                          • July 31, 2000
                          • 640
                          Jack,
                          Gary
                          Gary, thanks for the clarification. My reply was somewhat of a "senior moment". I was focused on the removal of the rubber bushing from the cross member. As I recall when I did mine the bushing's outer metal sleeve rusted/welded itself to the cross member's inner surface. Thanks again.
