Corvette Bolts - NCRS Discussion Boards
Corvette Bolts
  • Jimmy G.
    • November 1, 1979
    • 976
    Corvette Bolts
    I spent most of my life in production environments and even today I can be amazed at what happens in manufacturing.
    For those of you who think everything was cookie cutter at GM look at the photo of the bolts I found today.
    This is not trick photography either. needless to say, no two Corvettes are exactly the same --- but of course we knew that already
    Amazing what the General accepted from suppliers sometimes
  • Harry S.
    • July 31, 2002
    • 5295
    Re: Corvette Bolts
    Ug, no points for you!
    • Mark E.
      • April 1, 1993
      • 4536
      Re: Corvette Bolts
      If your supplier just delivered a month's supply of valve cover bolts needed to keep production running, and the only defect is cosmetic, would you reject them?
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Bill M.
        • 1322
        Re: Corvette Bolts
        No and I am sure when needed the manager sent someone to the local hardware store to get a few boxes all the time. they never figured guys would go insane over mismatched hardware.
        • Mike B.
          • July 31, 1994
          • 839
          Re: Corvette Bolts
          Good Morning Jimmy,
          I was buying lots of classic bolts from a guy up in Pennsylvania years ago and ran across these two anomalies. I'm sure Towne Robinson didn't intend for errors to slip by but as we can see they did.
          These two won't be used on my cars. On display in my shop now as a novelty. Take care, Mike
          • Jimmy G.
            • November 1, 1979
            • 976
            Re: Corvette Bolts
            I think we should put them on a judged car so judges can see that not everything is ABSOLUTE
            • Ed S.
              • August 6, 2014
              • 1377
              Re: Corvette Bolts
              You think those bolt heads are rare - check this out!
              Trick or Treat!
              Ed
              • Harry S.
                • July 31, 2002
                • 5295
                Re: Corvette Bolts
                That would be interesting but probably still not worth a point. 20% of one point is a slash and a comment. (Depending on how you weigh the hardware)
                • Mike B.
                  • July 31, 1994
                  • 839
                  Re: Corvette Bolts
                  Jimmy,
                  So I could use my two bolts in the upper fan shroud corners of my '66 during judging. What a reaction there'd be! Tempting.
                  Mike
                  • Ed S.
                    • August 6, 2014
                    • 1377
                    Re: Corvette Bolts
                    I would suggest installing them in a place where judges would have to use a mirror to inspect --- so when they viewed them in the mirror the font would be oriented correctly.
                    Ed
                    • Wayne H.
                      • August 19, 2018
                      • 58
                      Re: Corvette Bolts
                      Not over 50 years later, that's for sure.
                      • Richard G.
                        • July 31, 1984
                        • 1715
                        Re: Corvette Bolts
                        Too bad its not a penny!
                        • Gary J.
                          • April 1, 1980
                          • 1241
                          Re: Corvette Bolts
                          I am having an epiphany over an anomaly of those TR bolt heads....
                          • Gary B.
                            • February 1, 1997
                            • 7018
                            Re: Corvette Bolts
                            Ed,
                            My thought exactly. And most people probably wouldn't even make the connection that the headwork must be mirrored.
                            Gary
                            • Paul Y.
                              • September 30, 1982
                              • 570
                              Re: Corvette Bolts
                              You guys are a fun group with all that judging speculation. I am enjoying the humor.
                              It's a good life!
