'74 Tilt/Telescoping steering column shift tube question - NCRS Discussion Boards
    • November 1, 1998
    • 143
    Hi all,
    Needed to rebuild the steering column in the '74 because the bearing housing support was worn out and the mast jacket was cracked. During the rebuild I found that the shift tube was also loose. Does anyone know the angle between the shift tube key and the lever on the lower tube? There were no alignment marks on tubes that I could see, I do have the length of the tube but have not been able to find the angle of the lever and key.
    Thanks in advance, Jack
