I purchased a Group 2 battery from Restoration Battery Co. a few years a go. My understanding is that it contains a 6 volt Optima battery in a correct Delco case with correct caps. The battery has never been significantly discharger but will now only recharge to about 6.32 volts. After about a week the charge will read about 6.26 volts. While the battery will start the car when cold, after a run and shutdown, say after a fuel stop, particularly when hot after a run on an expressway, it is difficult to restart.
I tried to contact Restoration Battery Co. but apparently it is no longer in business. Any one know who took over this business?
There are number of 12 volt lithium-Ion jump starter but I've not been unable to find a 6 volt one. Anyone know if one is available?
If not, any suggestions on how to make one?
Any help or suggestions would be most appreciated
My car is an early 1954 (S/N E54S001526) with the 2-field coil starter. Also would like to purchase a 4 field coil starter.
Tom Gamache
Tom Gamache
