1970 1/2 shaft bolts - NCRS Discussion Boards
  • Rick N.
    • August 25, 2017
    • 141
    I read in the 1970-1972 judging manual that the inner u joint cap bolts for the 1/2 shafts are supposed to be black in 1970 and early 1971.
    All other years that used these bolts are silver.
    I'm familiar with most if not all of the manufactures that made these bolts and I've only seen silver.
    Can someone verify for me that in 1970 they are definitely supposed to be BLACK ?
    Also, what head marking?
    Thanks, Rick
  • Ron G.
    • December 1, 1984
    • 865
    Re: 1970 1/2 shaft bolts
    Rick,
    It has always been my experience that the bolts that attach the rear end yokes are grade 5 and were plated silver cadmium and the lock washers were black oxide. However, the bolts that attach the outer axle flange are grade 8 and were plated black oxide with black oxide lock washers. Hope this helps.
    - Ron
    "SOLID LIFTERS MATTER"
      • 43246
      Originally posted by Ron Goduti (8076)
      Rick,
      - Ron
      Ron------
      The bolts on the outer u-joint flange did not use lockwashers. French locks were used.
      • Ron G.
        • December 1, 1984
        • 865
          • 43246
          Joe - I am getting old. I know that, but can’t remember everything even though that is elementary. Thanks for reminding me. - Ron
          Ron------
          I figured you must have had a "senior lapse". It happens to me, too. In fact, it happened recently on a discussion about ZR-1 radiator hoses. I spec'd out hoses that I had previously determined would not work.
