GM number 3774937 fuel level sender locking cam (lock ring) markings - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2150
    I've noted "O2" stamped on the fuel sender locking cam sold (but not made by) Paragon as number 3860. It's listed for '63-'74.
    Both the 1965 A.I.M. (UPC 8, B1.) and my old GM box of ten reference GM 3774937. Those ten I bought in the seventies had "A" stamped on them. I've decided to use the "A" version for my most recent project, but now I am curious...
    My NCRS 1965 TIM&JG is to be consulted in a few minutes, as it's not nearby at the moment. (I will add to this is I find something therein.)
    The NCRS 1963-1964 TIM&JG does not mention this ring. Also, my NCRS 1966 TIM&JG does not mention it.
    The NCRS 1968-1969 TIM&JG 5th edition, Chassis page 242 31 is often found on the sending unit mounting ring, but other numbers have been seenNCRS 1970-1972 TIM&JG 5th edition, Chassis page 222 31I wonder what locking cam numbers have been seen on original 63-67 Corvettes. If not "31", I wonder what '65s had...
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Larry M.
    • January 1, 1992
    • 2702
    Re: GM number 3774937 fuel level sender locking cam (lock ring) markings
    I have only seen "A" for the C2 cars.
    Larry
    • Mike M.
      • May 31, 1974
      • 8408
      i have six original lock rings off c2s , all have GH stamped on them. GH, not GM.. mike
      • Don H.
        Moderator
        • June 16, 2009
        • 2283
        the 6th 1965 JG says the cad or zinc plated locking ring secures the sender unit but does not say if anything is marked thereon. Chassis Pg. 228.
          • 43288
          The NCRS 1968-1969 TIM&JG 5th edition, Chassis page 242 states “…mounted in the tank with a zinc-plated locking ring. 31 is often found on the sending unit mounting ring, but other numbers have been seen. “ (Way to go Patrick and team!)
          The NCRS 1970-1972 TIM&JG 5th edition, Chassis page 222 states “…mounted in the tank with a zinc plated locking ring. 31 is often found on the sending unit mounting ring. “
          Tom------
          I'm very confident that the embossments on these cams represent a manufacturer's ID. These cams were used on just about all GM cars and trucks in the 1961-74+ period. So, there were millions of them being made and, likely, by multiple manufacturers, either at any given time or over the years of manufacture. I have seen "A" and "G.H." and there are probably others, too. Almost 60 years after its release, the GM #3774937 is still available from GM for about 5 bucks, GM list.
