1957 Jacking instructions Limited slip warning labels - NCRS Discussion Boards
  • Dan P.
    • December 1, 1990
    • 683
    The JM says the Label is 6X9. Corvette Central is 8 1/2 X 5 1/2 Does anyone make the correct size.The JM says it is in the left side . The original one in my car and A Bowtie car i have seen is in the right side.
  • Mike M.
    • May 31, 1974
    • 8398
    Re: 1957 Jacking instructions Limited slip warning labels
    place it on the passenger side of the plywood. as far as size, I'd go with 6 x 9 but I doubt many judges would be carrying a tape measure. regards, mike
    • Rod K.
      • 443
      Dan, I went through this exercise a while back. Paragon has a p/n 12987 label they say is a "correct reproduction" (whatever that may mean) that is 8-1/2 X 5-1/2. My intent is to obtain and recopy onto larger paper and cut down to the correct 9 X 6. My label was rotated about 30* CCW and placed approx. in the 4-5 o'clock position on the tire cover board.
