59 Door post - NCRS Discussion Boards
59 Door post
  • Roger W.
    • January 29, 2008
    • 572
    59 Door post
    I have a 58 door on the driver side of my 59. The door post does not have the 4 threaded holes for the weatherstrip clips. The post needs chrome plating, but otherwise is in good shape. Should I try to find a vendor that woul drill and tap the holes in the correct locations or find a vendor that would take my post in a trade in toward the purchase of the correct door post?
    Roger
  • Terry D.
    • May 31, 1987
    • 2697
    Re: 59 Door post
    Be Cheaper to do it yourself
    • Dan B.
      • July 13, 2011
      • 545
      Re: 59 Door post
      An exchange door post may not fit your car well and the gaps may be off. Seen this happen a few times. Best to keep what you have, do the modifications, and then get it chromed.
      • Roger W.
        • January 29, 2008
        • 572
        Re: 59 Door post
        Terry and Dan,
        Thanks for your advice. You reminded me that I have had a few NOS chrome moldings that did not fit nearly as good as my originals.
        • Tom B.
          • March 1, 1978
          • 726
          Re: 59 Door post
          When I got my '59 back in 1969 it also had a '58 door on the right side due to a prior accident. I noticed that the post was different too but the big deal was when I tried to install the interior trim panel and I discovered that the inside door release handle was higher and further back on a '58 door and the '59 panel won't fit. I found a '60 door that is the same as a '59 and swapped doors. '58 handle is above the trim molding in the vinyl and the '59 is below the trim molding in the metal panel area.
          • Roger W.
            • January 29, 2008
            • 572
            Re: 59 Door post
            Tom,
            Thanks for pointing out the different position of the inside door handle. I never noticed the difference, as my original door panel was pretty well messed up.
            • Tom B.
              • March 1, 1978
              • 726
              Re: 59 Door post
              Roger,
              I wasn't sure that you realized that there was a difference and didn't want you to spend too much time working on the '58 just to find out it wasn't going to be right in the end.
              • Roger W.
                • January 29, 2008
                • 572
                Re: 59 Door post
                Tom,
                I didn't notice the difference. I am glad that you told me about the handle position. It would not be too cool to find out after the car had a new paint job.
                • Pat H.
                  • December 1, 1996
                  • 421
                  Re: 59 Door post
                  My 59 had 58 door posts as well. As far as I could determine they were original to the car, but I found a set of decent 59 posts and swap them out after re-chroming them. I did not have a fittment issue. I eventually sold the 58 posts to a member that needed to re-chrome his 58 ones. With all the enviromental restrictions these day, I'm glad I did it 15 years ago.
                  • Roger W.
                    • January 29, 2008
                    • 572
                    Re: 59 Door post
                    Pat,
                    I am still pondering what to do about the post and door. I had forgotten that my 58 door had a square hole cut near where the 59 handle location would be be located. I had always wondered why somebody would cut this hole. I think that they gave up modifying the door for the correct handle location.
                    • Tom B.
                      • March 1, 1978
                      • 726
                      Re: 59 Door post
                      I suppose that you could relocate the handle mechanism. Make a template off of the other side to correctly locate the handle after you glass in the hole.
                      Tom
                      • Daniel J.
                        • July 29, 2007
                        • 158
                        Re: 59 Door post
                        If you are early in your restoration...I would recommend finding a door & post for a '59 - '60.
                        There are many small differences between '58 & '59-'60 and you will be fighting it.
                        Just my opinion (based on experience)
                        • Roger W.
                          • January 29, 2008
                          • 572
                          Re: 59 Door post
                          Dan,
                          I know some of the stainless molding and mounting brackets on the top of the door are different. I have already gotten the correct 59 parts.
                          • Roger W.
                            • January 29, 2008
                            • 572
                            Re: 59 Door post
                            Tom,
                            I am leaning towards relocating the handle, since my inner door panel is already damaged with a hole.
