67 Corvette Wheel Weight Sizes - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 397
    Hi:
    Does anyone know what the weight range for balancing weights were used? My question is was 1/2, 3/4, 1 oz, 1.5 oz, 2 oz, 2.5oz, 3 oz, 3.5 oz, 4 oz, 4.5 oz, and 5 oz all used? If not, which ones were? I did a search and came up with no answers. I did come up with the answer that no more than 5 ozs was applied to a wheel/tire combination. Thanks!
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
  • Gary B.
    • February 1, 1997
    • 7018
    Re: 67 Corvette Wheel Weight Sizes
    Thomas,
    Only multiples of 0.5 oz, up to 2.5 oz were used on the production line for C2s.
    Gary
    • Gary J.
      • April 1, 1980
      • 1241
      What would have happen if a tire required a weight higher than 2.5 ounces? Would it have been a quality control issue?
      • Gary B.
        • February 1, 1997
        • 7018
        Up to 5 oz out of balance was acceptable, using combinations of the allowable weights. After that, I suppose remount or reject were the options.
        Gary
        • Thomas N.
          • July 31, 2002
          • 397
          Thanks for the responses!
          • Jack M.
            • March 1, 1991
            • 1153
            Wheel weight info can be found in the 1967 Assembly Manual (similar to what has already been written):
            Enlarged text:
            • Mark L.
              • 560
              Jack, also the bolt on wheels used a unique weight. Part numbers are listed under the optional wheel.
              • Jack M.
                • March 1, 1991
                • 1153
                Mark- Indeed... and the listed weights went up to 3 oz for those optional wheels.
                • Ray G.
                  • May 31, 1986
                  • 1189
                  Hello
                  2 correct wheel images ... available on line.
                  Ray
                  I hope you dance
                  • John D.
                    • June 30, 1991
                    • 875
                    When I worked in the plants tire/wheel assemblies that needed total weight beyond the limit were rejected and disassembled. One common reason was excess soap/lubricant mix sloshing around inside the tire.
                    • Thomas N.
                      • July 31, 2002
                      • 397
                      Ok..So I now have my tires mounted, and checked the static balance. Two of the tires need one oz each, and two tires need 4 ounces each.
                      According to the AIM (thanks Jack) provided, note 4 says (not paraphrased) that you can add weights to either side of wheel at rim edge, and splitting of weights may be done if desired. My question is did they add weights to both sides of the rim (2 ozs front 2 ozs rear) or could I just add two two ounces to the back side of the rim? My concern is that weights on the front would interfere with the clips on the trim ring. I thought I heard somewhere that weights were not placed on the front lip of the wheel. Thanks for any insight you can further provide.
                      • Leif A.
                        • August 31, 1997
                        • 3627
                        I brought this point up once before, regarding paragraph #4 above. I was told the factory never installed weights on the rallye wheels on the outside, no matter what was printed in the A.I.M. Your reasoning is correct, they would interfere with the trim ring installation.
                        As an aside, your tire/wheel combos that need the 4 oz of weight to balance...you might try letting the air out of those two, rotating the tire on the rim 90* and see what happens. Just a thought.
                        Leif
                        • Thomas N.
                          • July 31, 2002
                          • 397
                          Leif:
                          Thanks!
                          I did rotate a couple of times to get the best balance possible.
