Is this an original assembly line fan clutch for a 69 L71 - NCRS Discussion Boards
  • Lawrence S.
    • April 1, 1993
    • 803
    This is off my car and did not know if this was original or not?
  • Ed S.
    • August 6, 2014
    • 1377
    Re: Is this an original assembly line fan clutch for a 69 L71
    Lawrence - there was a great article on mid-year fan clutches that appeared in the Kansas City Chapter news letter back in 2012. The article has been reduced to a PDF and is available for reading at the link below. Info in the article might help you answer your question. Discussion on Scwitzer units begins on page 3.
    Ed
    • Jeffrey S.
      • May 31, 1988
      • 1890
      The configuration appears to be an original Sweitzer unit. There should be some stampings along the edge of the mounting flange. Usually it has "SC" for Sweitzer, and a date code. Check to see if the date lines up with the production of your car. If it does then it most probably is original to your car.
      Jeff
      • Mike E.
        • February 28, 1975
        • 5141
        That article does not extend to C3 applications, so info on shaft length, etc is not apropos for a ‘69. It is a very helpful article, though. Thanks for citing it!
        https://www.ncrsmac.org/ed/Engine/Fa...%20-%20C2s.pdf
          • 43247
          Lawrence------
          The fan clutch pictured is a GM #3937771. It's the fan clutch likely originally used for your application. If the date works for the car's build, then it's likely the original clutch.
          • Jimmy G.
            • November 1, 1979
            • 977
            Check the date on the flange to verify the production date
            • Lawrence S.
              • April 1, 1993
              • 803
              Yep original fan clutch. Check out the date on the base.
              • Jimmy G.
                • November 1, 1979
                • 977
                Must be an early car
                • Lawrence S.
                  • April 1, 1993
                  • 803
                  Yea, September 68 car, you have not seen this car Jimmy. Original Paint L71 Fathom Green, Saddle Roadster, 25K miles with a tank sticker, 4.11's Just a neat driver with side pipes...which were added.
