Volt regulator - NCRS Discussion Boards
Volt regulator
  • Brad H.
    • August 12, 2007
    • 724
    Volt regulator
    Hi guys... I have a Delco volt reg. stamped 1119277D 12VN OJ. Anyone tell what cars that might be used on and could it be used on late fifties-thru sixties Corvette? Thank you.
    • 43248
    Re: Volt regulator
    Brad------
    GM #1119277 was never originally used on a Corvette. The only application I can find for it is early 1960's Studebaker passenger cars. Lots of Delco-Remy components were originally used on non-GM applications.
    • Brad H.
      • August 12, 2007
      • 724
      Re: Volt regulator
      Hi Joe and thank you for the reply. Could that part be used on a 60-61 Corvette. Thank you again, Brad.
        • 43248
        Re: Volt regulator
        Brad-----
        That I cannot answer. I suspect it could be used but I don't know that with any certainty.
