1954 radiator cap - NCRS Discussion Boards
1954 radiator cap
  • Guy M.
    • November 1, 1993
    • 500
    1954 radiator cap
    My 4# cap just isn't cutting it, coolant leaks by it. The car runs fine and doesn't overheat. Has anyone run a 7# cap? See any issues doing it? Even NAPA shows a 7# cap for any 54 chevy with a 6 cyl.
  • Brad H.
    • August 12, 2007
    • 724
    Re: 1954 radiator cap
    Hi Guy... correct Rad. Cap. AC. 778 #4 restored to new by Joe Perri worked perfect on my 54. hake1@comcast.net
    • Bob W.
      • December 1, 1977
      • 803
      Guy, Joe perri past away a few months ago Tim a ncrs member purchased his business. Check out the post Radiator and gas caps for his phone number.
      • Guy M.
        • November 1, 1993
        • 500
        Thanks guys I appreciate the help. Has anyone run a 7# cap? What might the ramifications might be? I have a high performance core in my radiator. Should be able to handle 7# you would think.
        • Guy M.
          • November 1, 1993
          • 500
          I still have this issue, will a 7# work just for driving around a bit without ramifications? Thanks!
          • Jim L.
            • September 30, 1979
            • 1817
            I would use it without hesitation, Guy. In fact, I believe that's what is on my own '54.
            • Guy M.
              • November 1, 1993
              • 500
              Thanks Jim, I sure appreciate that confidence boost. I can always put the 4# if judging.
              • Tim B.
                Infrequent User
                • September 12, 2019
                • 9
                Guy,
                There are 2 gaskets in your Radiator Cap. It could be the internal one leaking. I can check out your Cap and see if it just needs a rebuild. Also I can replace the 4# spring with a 7# spring if needed or desired .
                Tim Bartsch
                GEN2 Restorations
                • Brad H.
                  • August 12, 2007
                  • 724
                  I have a perfect AC 778 #4 Joe Perri cap. Brad.
                  • David L.
                    • July 31, 1980
                    • 3310
                    Is the 53-55 Corvette chrome 4# radiator cap, GM # 850778, the same as the 48-53 Chevrolet passenger car cap, GM 850796, except for the chrome plating? I have a used 850796 cap stamped "AC", "501", and "4#". My 1957 Chevrolet Parts Catalog describes the 850796 cap as "pressure type (dbl. ear-marked 501)".
                    Dave
                    • Tim B.
                      Infrequent User
                      • 9
                      The "501" is a service, over the counter replacement for the 850778 Radiator Cap. It will function the same as the "778" Cap.
                      • David L.
                        • July 31, 1980
                        • 3310
                        Tim,
                        Is the chrome 53-55 Corvette cap stamped "778" and the 53 Chevrolet cap stamped "796"?
                        I have a NOS AC cap in the blue AC box labeled RC-3 7# 850797 with the cap stamped "AC", "MADE IN USA", "PAT'D", "13" AND "7#". The specification chart and instruction sheet inside the box is dated July 1954.
                        I also have a NOS AC cap in the blue AC box labeled RC-12 9# 850994 with the cap stamped "AC", "940 - 9#", "RC-12", "MADE IN USA", and "PAT'D".
                        Dave
                        • Guy M.
                          • November 1, 1993
                          • 500
                          Thanks for all this info, I would love to get the correct cap, anyone have one and willing to part with it? Then ill send it to Jim to put a 7# spring in it if he's willing to do it. Thanks again Jim and all!!
                          • Brad H.
                            • August 12, 2007
                            • 724
                            Guy, I have a correct 53-54 restored cap. A.C. 778 #4 by Joe Perry. ncrs Classifieds car parts C1, craigs list 7153380400. 360-580-3426 Brad.
