Pre-Lube 6 - NCRS Discussion Boards
Pre-Lube 6
  • James W.
    • December 1, 1990
    • 2676
    Pre-Lube 6
    Where can it be purchased?
    James West
  • Larry M.
    • January 1, 1992
    • 2702
    Re: Pre-Lube 6
    Google is your friend.
    Here is one source with reasonable prices. Some sites offer in 5 gallon pails or a case of 12. But I am sure that is not what you want.
    Larry
    • Gary S.
      • July 31, 1992
      • 1633
      Re: Pre-Lube 6
      I bought 2 cans of it many years ago (15 or so) from Quanta Products.
      Gary
      • Ron G.
        • December 1, 1984
        • 866
        Re: Pre-Lube 6
        James,
        I purchased just 1 can of Pre-Lube 19 which is for parts that are exposed to heat such as exhaust manifolds and pipes. He also sells Pre-Lube 6. His name is Henry and he will sell you 1 can if that is all you need. He is located in PA. Henry's contact number is: (215) 426 - 0601. Hope this helps.
        - Ron
        "SOLID LIFTERS MATTER"
        • Dick W.
          • 10483
          Re: Pre-Lube 6
          My local NAPA store has/had it
          Dick Whittington
          • Jeff P.
            • 799
            Re: Pre-Lube 6
            LOL , wanted to see if Amazon has it. Not going to explain what came up. Not car related. LOL
            68 L79 Convertible: Triple Black: Work In Progress, Body off. Now on!
            2014 Arctic White Z51 Vert. (Wifes)
            • James W.
              • December 1, 1990
              • 2676
              Re: Pre-Lube 6
              I think I found the same thing a few days ago when doing the same search!
              James
