midyear steering - NCRS Discussion Boards
midyear steering
  • Dave K.
    • November 1, 1999
    • 952
    midyear steering
    I have a 65 coupe with manual steering (tele column) and a 66 roadster with manual steering (standard column). Both columns have been recently rebuilt. I replaced the steering box on both cars with rebuilt steering boxes. Tie rods are in the outer knuckle holes. I rebuilt both relay rods and lubed the linkage on both cars. However, I notice that the convertible is harder to steer (stiffer) than the coupe. Any ideas?
    Dave K.
  • Stephen L.
    • May 31, 1984
    • 3161
    Re: midyear steering
    Different tires/pressures???? Different engine weights???
    • Rich G.
      • August 31, 2002
      • 1403
      • Jim L.
        • September 30, 1979
        • 1816
        Caster has a significant effect on steering effort. Are both vehicles aligned to have the same caster?
        • Paul Y.
          • September 30, 1982
          • 570
          I know this may sound crazy but my friend, who purchased my 1972 back in 1987, asked me to convert it to power steering for him and his wife.. I never remembered it steering too hard when I owned it so I checked the steering box. Low on fluid. I got my trusty drilled through bolt with the grease zerk tapped into the top and filled the box with a high quality grease until it came out the lower bolt. Problem solved and that was about ten years ago. So maybe check the lubricant in the steering box. I always try simple fix first.
          It's a good life!
          • James W.
            • December 1, 1990
            • 2668
            Paul,
            What type/kind of grease did you put in the steering box?
            James West
            • Paul Y.
              • 570
              Originally posted by James West (18379)
              Paul,
              James West
              James, the first one had a cartridge from GM that Joe V recommended as a good universal grease.. after that was used up on misc. other things I used a good synthetic high temp grease from the parts store. I usually have more empty grease guns than I do cartridges.
              It's a good life!
              • Dave K.
                • November 1, 1999
                • 952
                The 66 has new ball joints and the 65 has worn ball joints. The66 steering should be stiffer. I figured this out myself.
