Trailer Tie Down Methods for 1992 C4 - NCRS Discussion Boards
  • Gary C.
    Administrator
    • October 1, 1982
    • 17940
    Question - what is the best tie down method to use for 1992 C4 ZR-1? Any special tie downs required?
    Am used to trailering C1 & C2 by using tie down straps to front and rear suspension.
    Thanks in advance.
    Gary
    NCRS Texas Chapter
    https://www.ncrstexas.org/
  • Guest
    Re: Trailer Tie Down Methods for 1992 C4
    Gary I always used two straps front and rear on my 89 Callaway I crossed tied the rear straps and ran the front straps over and around the A frames
    You just have to be careful of the front air deflector
    Mark
    • Gary C.
      Administrator
      • October 1, 1982
      • 17940
      Mark,
      Thanks. Was wondering if the A Frames or shipping holes were used for the tie downs.
      Hopefully, the 2 - 2x12's am adding to the floor of my trailer will help with the front air deflector clearance. I had to add 2x12's to haul Gilbert's '84 for him, but forgot how the tie downs went.
      Gary
      NCRS Texas Chapter
      • Richard G.
        • July 31, 1984
        • 1718
        Unsure it this is even possible with the 1992's but here goes.
        Whenever possible I tie down the tires and let the car float on the suspension.
        The trailer tows so much smoother it's downright amazing.
        As an additional benefit it removes much of the shock loading from the tie down straps.
        Down side is it typically requires special straps designed to go over the tires.
        • David K.
          • September 30, 1979
          • 241
          E track and over the tire ratchet straps on all four tires
          • Roy S.
            Past National Judging Chairman
            • July 31, 1979
            • 1027
            Yes Sir, e track over tire ratchet straps on all four tires, all of the later model lower ground clearance vehicles work best this way, allows you to put ratchet in front of the front tires and behind the rear tires where they can be properly tightened. With no worry about abrasion, interference, flex from long straps or awkwardness of operating ratchets around the body.
            • Gary C.
              Administrator
              • October 1, 1982
              • 17940
              Appreciate your all's recommendations. Thanks,
              Gary
              NCRS Texas Chapter
              • Mathew S.
                • July 9, 2015
                • 137
                When I was autocrossing my C4, I used the factory tie down points. These are located at the back of the front wheel well, and front of the rear. They are an eyelet and used the 10k lb hook straps. Towed all over the country this way with no issues.
                • Tom H.
                  • December 1, 1993
                  • 3440
                  That's how I always tied the C4's down !
                  Tom Hendricks
                  Proud Member NCRS #23758
                  NCM Founding Member # 1143
                  • Ed N.
                    • May 16, 2010
                    • 1003
                    Gary I strap my C4 over the tires and never had a problem.
                    Ed Nieves
                    NCRS #51799
