1975 shock labels what is correct? - NCRS Discussion Boards
  • Bob B.
    • January 31, 2007
    • 525
    I have a 75 Convertible L-82 with FE7 Gymkhana suspension what is the correct shock and label ?
    Judging guide says PF rear AC front label
    ZIP EN EP
    Pacifica something else
    How about a bit of help ?
    THANKS, Bob
  • Tom R.
    • June 30, 1993
    • 4102
    Re: 1975 shock labels what is correct?
    Gymkhana from 75-78 called out GM# 4984577 (front) and 4984578 (rear) shocks. Labels I've seen for those shocks were CK (front) and CE (rear). Buildsheets typically call out the broadcast codes and why the labels were used in the first place. However, 76 was the first year we begin to see the codes printed on the buildsheet and we see the CK, CE codes called out.
    Tom Russo
    78 SA NCRS 5 Star Bowtie
    78 Pace Car L82 M21
    00 MY/TR/Conv
    • Bob B.
      • January 31, 2007
      • 525
      OK I will look on the build sheet THANK YOU
      Bob
      • Tom R.
        • June 30, 1993
        • 4102
        I doubt they'll be there for a 75 but keep us posted.
        Tom Russo
        78 Pace Car L82 M21
        00 MY/TR/Conv
        • Bob B.
          • January 31, 2007
          • 525
          Thanks, there is a CK on the build sheet and next to that AX and HB on the other side. I will pull my Build sheet book out this evening when I have more time and see what space on the build sheet calls out the shocks will let you know
          Bob
          • Tom R.
            • June 30, 1993
            • 4102
            If you're referring to the boxes, its 17 and 18. What's your VIN?
            Tom Russo
            78 Pace Car L82 M21
            00 MY/TR/Conv
            • Bob B.
              • January 31, 2007
              • 525
              Tom Russo, as in the Tom Russo that wrote the book ? Well, OK then vin 420824 build 3/31/75 build sheet box 35 is CK
              14 / blank 15/HY HY 16/AJ 17/blank 18/RC 19/522521 21/596
              Answer anything ?
              THANK YOU BTW I have just about every document on this 75 window sticker, shipper, tank sticker, if anything is of use
              • Tom R.
                • June 30, 1993
                • 4102
                Not really!
                • box 35 is CK = doesn't the caption read V-belt groove?
                • 15/HY HY 16/AJ = springs front and rear
                • 17/blank 18/RC = shocks
                • 19/522521 21/596 = strg knuckle and stab bar (FE7)
                Answer anything ?
                It appears that the codes/blanks shown for 17 and 18 is typical for buildsheets in 1975. Do you have the part numbers stamped into the shocks? Photos? Can you post or send me a scan of your buildsheet? hunt4cleanair@earthlink.net
                Tom Russo
                78 Pace Car L82 M21
                00 MY/TR/Conv
                • Bob B.
                  • January 31, 2007
                  • 525
                  Unfortunately the original owner ( I bought from him) tossed the original shocks and installed KONIs so S O L
                  I will send you a copy of the build sheet Bob
                  • Tom R.
                    • June 30, 1993
                    • 4102
                    I stand corrected...CK is correct for the front but rears were CL.
                    Tom Russo
                    78 Pace Car L82 M21
                    00 MY/TR/Conv
                    • Guy F.
                      • March 1, 2001
                      • 318
                      Here is what I read from the shocks on my '75 convert L-82/M-21 with FE-7, vin 19659:
                      Front shock: part number stamped: 4984666, date 03475 (2/3/1975) sticker: HN
                      Rear shock: Part number stamped: 4984803, date 01675 (1/16/1975) sticker: unreadable
                      I hope this helps.
                      Thank you,
                      Guy
                      Guy
                      '75 Convertible L-82/M-21 Silver/Silver L
                      '73 Coupe L-82/M-20 Med Blue/Black L
                      '23 HTC, 3LT, Elkhart Lake Blue/Jet Black red stitched, Z51 with mag ride,
                      FEL, 70th wheels, carbon flash roof, nacelles, mirrors, spoiler, full length stripes,
                      edge red calipers plus other goodies
                      • Tom R.
                        • June 30, 1993
                        • 4102
                        Could the front shock label be HY? I have buildsheets with FE7 and they show HY front and AJ rears.
                        Tom Russo
                        78 Pace Car L82 M21
                        00 MY/TR/Conv
                        • Guy F.
                          • March 1, 2001
                          • 318
                          Could the front shock label by HY? I have buildsheets with FE7 and they show HY front and AJ rears.
                          Could be HY. I will double check.
                          Thank you,
                          Guy
                          Guy
                          • Guy F.
                            • March 1, 2001
                            • 318
                            Tom if you zoom in on the label it says "H N"
                            Thank you,
                            Guy
                            Guy
                            • Guy F.
                              • March 1, 2001
                              • 318
                              More zoomage....
                              Guy
