auto transmission neutral safety switch 1958 - NCRS Discussion Boards
  • Ted K.
    • August 31, 1994
    • 337
    Engine starts with trans selector in Park as it should, however when moving the trans selector firmly into park with ignition key in off position the engine cranks. Obviously some wiring is incorrect but it is not obvious to me. Any suggestions?
  • Terry D.
    • May 31, 1987
    • 2692
    Re: auto transmission neutral safety switch 1958
    The St-12 has wiring diagrams in the back pages, also available from most vendors in a larger color print. If you are going to keep the car you should have these.
    • Ted K.
      • August 31, 1994
      • 337
      Thanks , but the wiring diagram I have does not show for auto transmission, but I will look again, just incase.
