Window Adjustment Woes - NCRS Discussion Boards
  • Floyd B.
    • November 1, 2002
    • 1046
    I cannot get the driver's side window to fit correctly on my '96 convertible. It seems like the regulator doesn't want to obey the stops and drives it 1/2" to high. If I lower the window about 1/2" it fits perfectly. I have the stops set as low as they will go and regulator drives the window up so far and so hard it bends the front stop upward about 15 degrees and it pushes up on the rear stop so hard it bends the door and makes a cracking sound. I also have the window set in the carrier as low as it will go. I have run out of options I can figure out on my own. Is it possible that the regulator is bad? It is a high mileage car - 98K.
    Thanx
    "Drive it like you stole it"
  • Richard G.
    • July 31, 1984
    • 1715
    Re: Window Adjustment Woes
    Take a look at this Corvette Central YouTube video.
    • Floyd B.
      • November 1, 2002
      • 1046
      Thanks. I saw that video (and about 10 other utube videos) but it doesn't address the problem I'm having. It's also for an older C4 and several changes were made to the adjusting hardware by the time my '96 was assembled.
