70 Corvette Headlight/Wiper Door Vacuum Relay Valve - NCRS Discussion Boards
  • Ronald R.
    • May 31, 1989
    • 671
    Does anyone rebuild these? thanks Ronnie
    • 15621
    Re: 70 Corvette Headlight/Wiper Door Vacuum Relay Valve
    Bob Demmel. Find his info in the member's listing from the above drop-downs.
    • Edward D.
      • October 25, 2014
      • 206
      You could just replace it with a new NOS valve. Its p/n 5638427 and although it was discontinued some years ago (Joe L could probably tell you when) they come up with regularity on eBay. I bought two last year for reasonable prices, around $75 each as I remember. Beware of the Chinese repros all the parts suppliers sell. Some work OK but others do not. Also the plating of the top diaphragm cover is wrong on the repros.
        • 43258
        Edward------
        As far as I can tell, the GM #8638427 was discontinued without supercession in 2010.
        Also, the part available from GM for about the last 5-10 years before its discontinuation had a silver plated top section.
        • Richard F.
          • September 30, 1981
          • 498
          I recently purchased 4 of them from Full Throttle (this is not an endorsement) they all tested perfect, I installed 3 of them and they all work perfectly. They were priced fairly and Full Throttle was very helpful.
          The top plate stamping is slightly different for a 1970 (I believe it may be correct for 1971- up) the plating is the correct type, the color code is too perfect as they relieve the plastic so the color sits in, and it does not have the Delco print on the plastic.
          But I'm Happy!
          • Ronald R.
            • May 31, 1989
            • 671
            I have those, they are nice but loose points. thanks RDR
            • Dick W.
              • 10483
              Edward------
              And the configuration of the now discontinued GM part was incorrect. Very easy to spot when you raise the hood
              Dick Whittington
              • Tom A.
                NCRS Body & Paint Advisor
                • May 31, 1986
                • 138
                Terry's recommendation of Bob Demel is right on. Bob does great work and is a Texas chapter guy. You won't be sorry.
                • Ron G.
                  • December 1, 1984
                  • 865
                  I agree with Terry and Tom they are both correct and Bob Demmel is definitely the guy. However, the only deviation may be in the configuration of the crimping of the two pie plates. Only a trained eye will notice.
                  "SOLID LIFTERS MATTER"
                  • Bob I.
                    • November 9, 2006
                    • 265
                      • 15621
                      Yes, he is. There was considerable work put into developing an unproved, but undetectable, relay valve. His product is better than original.
                      Now that I have put that out there I hope he has the materials to meet the demand.
                        • 11678
                        If not, we'll have to contact his materials guy to make more.
