Door Panel Install - NCRS Discussion Boards
Door Panel Install
  • Don G.
    Infrequent User
    • November 1, 1982
    • 12
    Door Panel Install
    I took the door panel off my 1959 in 1985, and decided it was time to put it back on the car. Fortunately I labeled all the parts, so that's not an issue. I have two questions. 1. Some of the holes in the door are too large for the trim screws that the door panel is attached with. What product should I use to repair or fill? 2. What is the lubricant of choice to lubricate the window regulator? Thanks.
  • Mike M.
    • May 31, 1974
    • 8381
    Re: Door Panel Install
    enlarged holes in door fiberglas a very common problem. i sand the backside of the hole then lay up a couple layers of fiberglass cloth and resin. let it set the drill a pilot hole smaller than the trim screws. i like lithium aerosol lubricant. mike
    • Don G.
      Infrequent User
      • November 1, 1982
      • 12
      Mike, thanks for the good advice, and thanks for not mentioning the fact that I haven't put the door panel back for almost 35 years.
      • Bruce W.
        • June 30, 1997
        • 358
        Don, you can also buy a repair kit. Small metal plates that you rivet to the door. The screw then does into the plate. You wn't have any more problems with this. I think Corvette Central sells the kits.
        Bruce
        • Don G.
          Infrequent User
          • November 1, 1982
          • 12
          Bruce
          Thanks Bruce, will check that out as well.
          • Terry D.
            • May 31, 1987
            • 2691
            I use small plastic screw inserts, find them on ebay or most vendors that have body screws, you need a very small file to make the hole square, snap the insert in and remove as many times as you like.
            • Don G.
              Infrequent User
              • November 1, 1982
              • 12
              Thanks Terry, sounds like an easy fix.
              • Richard G.
                • July 31, 1984
                • 1715
                They also make oversized screws with the small head and larger body.
                I didn't know about these till my upholstery guy showed them to me.
                Its like a #8 screw with the threads of a #10.
                Thanks everyone for the great ideas! I really like the Terry's idea using the plastic screw inserts.
                I bet you could find the clips here:
                clipsandfasteners.com
                They have a lot of parts and they are inexpensive.
                Here is an example.
                That's roughly $.18 each without shipping.
                Rick
                • Don G.
                  Infrequent User
                  • November 1, 1982
                  • 12
                  Thanks for the info Richard
                  • Keith R.
                    • August 31, 2001
                    • 660
                    In Tom Howey/Bob Baird's 58-60 Corvette Restoration Book, they used well nuts which can commonly be found at any hardware store. In my case, my body guy placed metal at each screw position on the rear side of the panel so that I could drill holes into them at the exact location and not worry about the holes becoming enlarged. Just installed my panels.
                    Keith MacRae
                    NCRS #36692
                    New Mexico Chapter
                    1960 290HP FI
                    2013 427 Convertible
                    Shade tree mechanic and
                    B-52 pilot extraordinaire
                    • Don G.
                      Infrequent User
                      • November 1, 1982
                      • 12
                      Thanks for the response Keith.
