63 rear end clunk - NCRS Discussion Boards
63 rear end clunk
+ More Options
Posts
  • Edward D.
    • October 25, 2014
    • 206
    Re: 63 rear end clunk
    Michael, are you asking about the alignment shims on the front pivot of the trailing arm or the spindle shims inside the arm? I assume its the former and the answer is the inboard shims are whatever is required to achieve a straight track with 1/16" total toe in evenly split across the centerline of thrust. The outboard shims are as many as you can get in there to fill. Objective being when you torque down the nut on the pivot bolt that the shims are bound tight and will not move by hand.
    • Michael G.
      • November 12, 2008
      • 2157
      Mike
      1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
      1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
      • Peter H.
        • April 1, 1980
        • 226
        #18
        Hello Michael.If your car is a pretty driver like mine,I use the 64/ slotted inboard square outer shims which tuck into the frame pocket.i can use a mirror to check their position and if all are present and accounted for..hope this helps. Peter # 3522. Canadian guy..
        • Michael G.
          • November 12, 2008
          • 2157
          #19
          Mike
