1962 Hood Release issues - NCRS Discussion Boards
  • David R.
    • June 29, 2014
    • 183
    The hood release on my '62 works just fine to open the hood - the handle pulls out fairly easily and the hood releases easily on both sides and pops up. However, I always have to manually push the handle back in or the hood won't latch when I close it. The handle doesn't retract at all after the hood releases. I have visually inspected everything and it looks like it's routed correctly, and I tried lubricating it. No change. Possible causes? Thanks in advance . . .
  • Frank D.
    • December 27, 2007
    • 2703
    Re: 1962 Hood Release issues
    Is it a reproduction handle and cable ?
    • David R.
      • June 29, 2014
      • 183
      No, not reproduction.
      • Terry D.
        • May 31, 1987
        • 2692
        Are you sure it is suppose to?
        • David R.
          • June 29, 2014
          • 183
          All of them I've seen do retract after pulling them and don't require pushing back in.
          • Dennis C.
            • June 30, 2002
            • 884
            Typically, if the cable routing is done without a bind or bend and the return springs are in good condition, then there is usually rust or corrosion between the inner wire and the outer cable. This indicates it is time for a rebuild.
            • David R.
              • June 29, 2014
              • 183
              Thanks, Dennis. The release handle seems to push back in pretty easily, without any binding that I can feel. Bad return spring(s), maybe?
              • Dennis C.
                • June 30, 2002
                • 884
                It is easy to try a new spring from the hardware store to see if it makes a difference and then go from there.
                • David R.
                  • June 29, 2014
                  • 183
                  Yeah, that's my plan. I'll be at Carlisle tomorrow, maybe i'll just pick up a couple of springs while I'm there.
                  • Tony R.
                    • April 19, 2017
                    • 201
                    And maybe some cable lubrication?
                    • David R.
                      • June 29, 2014
                      • 183
                      As I've said, the cable seems to move OK both ways - no binding at all. I have sprayed WD-40 (I know, I know - that's a solvent, not an oil) the length of the cable a few times over the years and it doesn't seem to do much - the cable worked OK before & after. I'll give it another shot at lubrication, though, after I swap in some new springs. What's everyone's favorite choice for lubricating the hood cable all along its length?
