1954 hood release too hard. - NCRS Discussion Boards
  • Guy M.
    • November 1, 1993
    • 500
    Hi all, im using repro male hood latches and they are REALLY hard to release. Have any of you had this issue and what did you do about it. Lubricate? Install original springs? Cut them? There is too much pressure. Thanks for your help
  • Chris S.
    • January 1, 2000
    • 1067
    Re: 1954 hood release too hard.
    on the male side - on the hood - the repro springs are WAY too stiff
    If you look at an original and a repro side by side
    The OE spring in thinner and less coils
    I buy OE male latches - and transfer the spring (if the latch is junk / pitted / etc....)
    Changes springs and you will notice a HUGE difference
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
    • Guy M.
      • November 1, 1993
      • 500
      Thanks Chris, Ill do that. Should there be any kind of lubrication on the male post? silicone spray maybe to make it easier to pull?
      • Chris S.
        • January 1, 2000
        • 1067
        white lith on the female part
