1962 Front Spindle - NCRS Discussion Boards
1962 Front Spindle
  • Terry D.
    • May 31, 1987
    • 2691
    1962 Front Spindle
    Does anyone know what the stock specs for a front spindle on 58-62 Corvette? Am looking for the diameter of spindle where inner race rides. As far as I have been able to search no one is reproducing these, please someone tell me I'm wrong!!
  • Richard G.
    • July 31, 1984
    • 1715
    Re: 1962 Front Spindle
    Terry;
    Typically when a bearing turns on the race there is an area, there is still the stock diameter, that sits outside the inner race contact area that isn't worn. This can typically be measured with a micrometer to acquire the size.
    It is a pain but the measurement can also be acquired from the other spindle by pulling the wheel.
    I have had them sprayed up and ground back down to the correct diameter in the past.
    Expensive fix but it works great. I could check with motor rewinding shops for this service.
    With all the retro rods being modified for coil overs one would think you could find the part used.
    If I had the bearing number I may be able to find the specifications in the bearing engineering book.
    Rick
    • Dick W.
      • 10483
      Originally posted by Richard Geier (7745)
      Terry;
      Typically when a bearing turns on the race there is an area, that is still the stock diameter, that sits outside the inner race contact area that isn't worn. This can typically be measured with a micrometer to acquire the size.
      Rick
      BCA NBB 52 and NBB 67
      Dick Whittington
        • 43219
        Terry;
        Rick
        Rick------
        The inner bearing was GM #909052 with an inner race ID of 1.281"
        The outer bearing was GM #909067 with an inner race ID of 0.750"
        • Terry D.
          • May 31, 1987
          • 2691
          Thanks guys, does anyone know where you can get them rebuilt?
          • Dennis C.
            • June 30, 2002
            • 884
            The process is called shaft metallizing. Check around at machine shops.
