C2 Rear End Yoke Balancing - NCRS Discussion Boards
  • Thomas N.
    • July 31, 2002
    • 408
    Hi:
    I am tearing apart a 67 rear end, and the rear end yoke has balancing weights on it. My question is are these weights to balance the yoke only, or is it balance for the entire rear end? The reason I'm asking is if it is to balance the entire rear end, I'm replacing the ring and pinion with a new set, and putting in a stronger posi basket and gears, and if would probably be not the same balance required. I appreciate any information you can provide.
    NCRS New England Chapter Chairman 2022, 2024
    N E Regional Chairman 2024
    1967 Corvette Convertible Under Restoration
    1996 Corvette Coupe NCRS Chapter Top Flight 99.5, NCRS National Top Flight 100.0
  • Gene M.
    • April 1, 1985
    • 4233
    Re: C2 Rear End Yoke Balancing
    I’ve not seen balance weights on the yokes on any cars worked on.
    Do you have photos of these?
      • 43284
      Originally posted by Thomas Nowak (10784)
      Hi:
      Thomas-------
      The weights are sometimes seen on the deflector attached to the pinion yoke. When present, they are usually small, rectangular metal tabs spot-welded to the deflector. Usually, only one or two tabs are present but I have seen as many as 5, as I recall. However, I have never seen such weights on GM SERVICE pinion yokes which are supplied with deflector. Unless this is only peculiar to the particular SERVICE yokes I've seen, this would lead me to believe that the balance weights were added as part of the differential carrier manufacturing process.
      As far as trying to rebalance a differential after parts are replaced, I've never heard of anyone doing it and I don't think there is any capability in the field SERVICE world to do it.
        • 43284
        A described weight can be seen on the original pinion yoke on my 1969:
        • Jim D.
          • 2885
          I don't recall ever seeing an original yoke without a balance tab.
            • 43284
            Jim-------
            I've seen some that did not have it (or, evidence of one ever being present) but they are, by far, the minority.
            • Richard G.
              • July 31, 1984
              • 1718
              "is to balance the entire rear end, I'm replacing the ring and pinion with a new set, and putting in a stronger posi basket and gears, and if would probably be not the same balance required. "
              Best guess is the yolk was static balanced. This would have been before it was assembled to the pinion gear.
              The yolk is a forging the center of gravity will vary.
              Because the input shaft is a machined part it is much easier to control the amount of unbalance.
              If it was me, I would just reinstall the yolk, as it, on the new gears.
              Rick
                • 43284
                Rick
                Rick------
                That's possible. However, if that were the case, I don't understand why it was not done on GM SERVICE flanges.
                • Richard G.
                  • July 31, 1984
                  • 1718
                  Joe
                  Good point.
                  However, having worked for big corporations for many years I understand anything is possible.
                  All it takes is one retiree and good practices go out the window.
                  • Thomas N.
                    • July 31, 2002
                    • 408
                    Thanks for the responses. I for some unknown reason am unable to post pics, but the above show exactly what I have. I figured the balance was for the casting only, but wanted to see if others had any insight.
                    • Darryl D.
                      • February 7, 2017
                      • 386
                      Rick
                      So, does this mean you need to pay attention to the original position before disassembly so it can be re-installed in the same position?
                        • 43284
                        Darryl-------
                        Well, whether it's essential I doubt but that's what I would do if I was re-installing a pinion flange on the pinion gear shaft it was removed from.
                        • Perry M.
                          • January 1, 1977
                          • 325
                          Such a small part with a small circumference, the inertia can't be much. Personally, I have never seen a weight on any of the cars I've owned, Corvettes or passenger cars. I know drive shafts are balanced but how many of you reinstall them in the exact same location on the yoke? When I had my half shafts shortened, the company that did the work said it was not worth the effort or expense to balance them because the inertia value was nearly undetectable. I realize the half shafts rotate 3 to 4 times slower than the yoke/driveshaft. If it were me, I would just reinstall the yoke.
