1967 M21 close ratio transmission questions - NCRS Discussion Boards
  • Jeff B.
    • April 30, 1980
    • 169
    Re: 1967 M21 close ratio transmission questions
    Roy:
    I have always thought the M21 transmission was available ONLY with rear end ratios of 3.55 and lower. Those with 3.36 and higher would get the M20. My car (437-390 4 spd, #8902) has the original AZ (3.55) rear end, and transmission thought to be an M21, based on the trans tag (3880853). It still has the original driven gear (green - 21 tooth). I've owned this car since 1978, and have talked to all previous owners. Am certain the drivetrain is original and untouched. Maybe this info can be of help.
    1967 Coupe 427-390 w/air
      • 43222
      Originally posted by Jeff Bartlett (3541)
      Roy:
      Jeff-------
      The 1967 L-36 and L-68 could have been equipped with an M-21 with 3.08: and 3.36:1. In fact, the 3.36:1 was the standard ratio supplied if no other was ordered
      • Roy S.
        Past National Judging Chairman
        • July 31, 1979
        • 1025
        #18
        Roy:
        Jeff, Thank You for the confirmation. I'm sure you are not the only individual with a 3880853 close ratio transmission big block Corvette if they retain their original ID tag and are M21 with 3.55, 3.70 or 4.11 they most likely have that tag.
        • Patrick B.
          • August 31, 1985
          • 1996
          #19
          • Mark L.
            • 561
            #20
            Roy,
            I agree. My 67 L71 had a transmission tag 3880853 and I'm pretty sure it was original to the car.
              • 43222
              #21
              Originally posted by Patrick Boyd (9110)
              Joe—-I have a 67 L-71 that came with a 3:70, but I changed the ring and pinion to a 3:36. Did GM or any one else ever make a plastic driven gear for this application?
              Patrick------
              If you're talking about a DRIVEN gear using the existing speedometer DRIVE gear from a 3.70:1 application for an application of 3.36:1 the answer is not that I'm aware of. For sure, GM never offered such a driven gear and I don't think anyone else ever did, either. That's because I don't think it's possible to make such a gear. If it could have been done, GM would have done it.
              The 3.36:1 application requires a 20 tooth DRIVEN gear. The lowest tooth count DRIVEN gear compatible with the DRIVE gear installed in your transmission is a 22 tooth green gear.
              • Gene M.
                • April 1, 1985
                • 4232
                #22
                Was there a time when you could/could not order a 3.70/4.11 gear with a wide ratio?
                Was there a time when you could/could not order a 3.08/3.36 gear with a close ratio?
                I was under the impression a 3.55 gear got a wide ratio tranny.
