Steering Column Ribbon Wire Routing - NCRS Discussion Boards
  • Patrick B.
    • August 31, 1985
    • 2017
    Would someone post some pictures of the ribbon wire routing? I am working on a 67 with a tele column if that makes any difference. Thanks
  • Gene M.
    • April 1, 1985
    • 4233
    Re: Steering Column Ribbon Wire Routing
    Are you looking for something other than it being inside the plastic sleeve?
    • Patrick B.
      • August 31, 1985
      • 2017
      The routing from outside the steering column to the dash side connector and where the dash side connector clips onto the underdash metal.
      • Stephen L.
        • May 31, 1984
        • 3162
        • Patrick B.
          • August 31, 1985
          • 2017
