Electrical 2003 - NCRS Discussion Boards
Electrical 2003
  • Frederick W.
    • February 1, 2006
    • 33
    Electrical 2003
    Hi Does any one know if the 2003 have been prone to electrical shorts. The reason I ask is because, I am having a problem. If I charge the battery up to over 12 volts, by morning the battery is below 5 volts and nothing works. If the battery is disconnected, the battery will stay charge. When it is fully charged and I go to connect the ground, it SPARKS badly. I have started to remove a fuse at a time to see if that circuit is the one causing the short, this could be a long process, I was never good at finding a short. This spring something filled the drain utter on the passenger side, which put a good layer of water on the floor, it did not seam to get in the fuse box, or computer. Thank You Fred
  • Dan D.
    • November 5, 2008
    • 1323
    Re: Electrical 2003
    Fred, try disconnecting the alternator. Bad (leaky) diodes will cause this problem. This used to be a problem on older cars as the diodes of the day were not that all good. But technology has improved greatly since then, and newer cars don't have this problem that much. But anything is possible.
    If that is not it, then you will have to disconnect things one at a time until the sparks go away.
    -Dan-
    • Richard G.
      • July 31, 1984
      • 1718
      Re: Electrical 2003
      Fred;
      I don't believe the C5 are prone to shorts. You didn't mention if the car is drivable or not. Without an amp meter to measure the load this will be difficult to trace.
      I do know you have a serious short or system malfunction somewhere and it could be a safety issue. It takes time, patience, tools and some knowledge to track down this stuff. If you lack any one of these attributes I would recommend taking the car to a professional.
      • Frederick W.
        • February 1, 2006
        • 33
        Re: Electrical 2003
        Hi Dan I have tried disconnecting the alternator, I have started to disconnecting things at the fuse box one at a time .I guest I was hoping for a short cut. I guest I know where I will be spending my time Thank You Hi Richard The car is drivable, but have shut off for to long. My wife has been wanting to move up in years, for the last 2 years now. However she says if I won't a new one, I have to get a job , but the Gov. is the only place to get a NO SHOW job Thank You Richard
        • Keith B.
          • September 15, 2014
          • 1596
          Re: Electrical 2003
          my dad had a 2000 with a CD holder in the trunk and somehow it "popped" open causing a drain on the battery. it took a while to figure that out
          • Frederick W.
            • February 1, 2006
            • 33
            Re: Electrical 2003
            Thank You Keith I do have CD holder in the trunk, it is not in there at this time. I will check to see if the connector might be shorting. I know the light has gone out in the radio screen. I know how to fix it, some time I what to take the radio out. I have pulled the radio fuse, that is not it. Thank You to everyone for your help Fred
            • Michael H.
              • December 1, 1987
              • 733
              Re: Electrical 2003
              This subject has been discussed numerous times on the Corvette Forum. There are some great threads on the Corvette Forum under C5 which will help find the problem. Check you seats as the lumbar motors may be running continuously. I agree with disconnecting your alternator and see if you still have a draw. You should also not have more than a 20-30 miliamp draw after the car is turned off for at 30 minutes.
