Did Quanta discontinue their semi-gloss black paint? - NCRS Discussion Boards
  • Michael L.
    • December 15, 2006
    • 1416
    Just went online to order some more of Quanta's semi-gloss black, which I bought years ago and am now finally running out. I can't find it on the website. Anyone know if they discontinued it?
    Mike
  • Harry S.
    • July 31, 2002
    • 5344
    Re: Did Quanta discontinue their semi-gloss black paint?
    If they did try John Deere Blitz Black, Yep the tractor company.
    • Dick W.
      • 10483
      SEMS also has a good semi gloss black
      Dick Whittington
      • John D.
        • December 1, 1979
        • 5507
        SEMS has a very good Semi Gloss Dick but slow drying.
          • 43279
          John-------
          For durability, slow drying paints are the best.
          • Dick W.
            • 10483
            At our age Chephart, what else do we have but time
            Dick Whittington
            • Barry H.
              • April 30, 1976
              • 213
              John, What ever happened to the GM Black Reconditioning Paint? We used to buy it 4 Gallon cans to a case. Part #1050104.
              Used for everything "Semi Gloss Black", from Frames to Ignition Coils, even dip painting small brackets.
              Barry Holmes
                • 43279
                Barry Holmes
                Barry------
                The GM #1050104 is GM-discontinued. However, a licensed reproduction of it is available and easily obtained through a number of Corvette parts vendors. It's about 100 bucks/gallon.
                This is what I call the "Ron Goduti Paint".
                • Dick W.
                  • 10483
                  Barry Holmes
                  I think PPG made that for GM. I bought many a gallon of it from PPG,before I switched over to urethane, when it was available.
                  Dick Whittington
                  • Gene M.
                    • April 1, 1985
                    • 4233
                    The enamel paints are slower to dry. You can mix a bit of hardener with the JD paint to speed up the drying time. But it is good paint either way.
                    • Jim D.
                      • 2885
                      Why not just buy this - https://www.globalindustrial.com/p/j...emi-flat-black
                      It's a perfect match to what the factory used and is lacquer so you can touch up at any time.
                      I've used it on several restorations. Here's a pic. of the latest.
                      • Michael L.
                        • December 15, 2006
                        • 1416
                        Jim,
                        That paint looks great. Did you spray that engine bay with rattle cans? I can't get a rattle can to finish that evenly when I do such a large area. Also, I need semi-gloss for things like brackets and pulleys, so not sure that would work but I'm sure Krylon makes a semi-gloss in the same paint.
                        Mike
                        • Steven B.
                          • June 30, 1982
                          • 4011
                          I just looked at my hour glass. There is a lot more sand at the bottom than at the top--- and I can't turn it over and start again!
                          • Jace H.
                            • April 1, 1997
                            • 253
                            I have had really good success with Krylon - semi flat. Used it on my 1967 roadster frame 17 years ago and it still looks great!
