I've looked this up in archives, but no satisfactory answer. 1965 JG and AIM both call for water pump pulley 3850979 for a car with C60 and N40. Does anyone have a pulley thus marked in a 65? If so got a pic or measurement?
What I have is a 3848904 pulley that is 6-9/32". The JG calls this pulley out as an alternate for the L76 engine,not the L79. When used with the 5-3/4" OD compressor pulley the 3849085 belt is too long. If the L76 compressor pulley 6-3/8" OD is used the belt is right length. But, the JG wants the smaller pulley on the compressor for the L79. I also have a 3770245 pulley that's 7-1/8" and is used on most L79s, but not with C60 per the JG. The belt also fits using this pulley.
So the question is, what size is the 3850979? I can find no technical info on it. Has anyone actually seen one or have one? This is not about making it work, I can do that. This is about judging points on a high end restoration in progress. Car is an original L79, C60, N40 coupe built 1/29/65.
Update: There are two possible belts 3849085, 56.75" long, used from 2/65 onward. 3847705, 57.50" long used 1964-2/65. I appear to have the longer 7705 belt. I'm going to get the shorter 9085 belt and it may cure the belt size issue using the smaller 8904 pulley.
But the main question remains: DOES ANYONE HAVE OR EVER SEEN A 3850979 PULLEY AND WHAT OD IS IT?
