C2 gauge services - NCRS Discussion Boards
C2 gauge services
  • Julio G.
    • March 28, 2017
    • 53
    C2 gauge services
    Greetings,
    Can anybody recommend a service that can fully restore gauges back to original condition without just buying replacement gauges or backing plates?
    Thank you in advance,
    Julio
  • Leif A.
    • August 31, 1997
    • 3651
    Re: C2 gauge services
    Joe Ray is a member here and his reputation is impeccable. Also, there are additional links at the bottom of this page for rebuilding services...should you feel the need.
    Leif
    • Richard G.
      • July 31, 1984
      • 1718
      Be sure to take pictures before sending anything off to vendors.
      Be clear on your expectations. My tachometer colors were redone in incorrect colors for a 63..
      Without pictures I couldn't prove it.
      Mine came back missing the original part number and date stampings on the back of the housing.
      It had been blasted and painted with aluminum paint, not re-plated.
      I am not sure why anyone would do that. Its extra effort and the backing plate was in great condition with no rust.
      It may not matter to many but I was disappointed with the results for this reason.
      If you are building a NCRS car have the front of the dash masked not taped off.
      Radio capacitors need to be installed before inserting the dash into the housing.
      Confirm the correct bulbs are installed in the headlight and p-brake warning lights.
      Remember the steering wheel can be unscrewed, from the backing plate, if the column is still in place.
      Makes it a lot easier to work on. Be sure you have the difficult to find clutch head screwdriver for these screws.
      Check the dash as thoroughly as you can when it arrives. Issues are much easier to deal with immediately after the rebuild.
      For instance my trip meter reset failed operations checks when it wouldn't reset.
      Many just give a year guarantee and you are out of luck after that.
      Rick
      • Larry M.
        • January 1, 1992
        • 2701
        I agree. Also Corvette Specialities of Maryland West (now in California) is also a tried and true gage restoration company. Either one will get you a first class job.
        Larry
        • Dick W.
          • 10483
          I will second Leif's recommendation
          Dick Whittington
          • Ken A.
            • July 31, 1986
            • 929
            Most gauges are not restorable to like new condition
            • Guest
              Rick Stotler - Joppa, MD another good shop - don't have info here at work but can provide
              • Gary C.
                Administrator
                • October 1, 1982
                • 17929
                Joe Ray's the best IMHO. You can send Joe an email from the Member's menu tab
                Gary
                NCRS Texas Chapter
                https://www.ncrstexas.org/
                • Richard G.
                  • July 31, 1984
                  • 1718
                  Likely the all beat the outfit I used in FL.
                  Rick
                  • Robert W.
                    • June 28, 2018
                    • 134
                    Rick's Restoration Svc. Joppa MD, (410) 538-4528 (He has a Facebook page, not a website). He does EXCELLENT work! -Bob
                    • Frank D.
                      • December 27, 2007
                      • 2703
                      I've dealt with Joe Ray and Brian of Corvette Specialties - both are excellent and stand behind their work.
                      • Patrick B.
                        • August 31, 1985
                        • 2011
                        • Jeff M.
                          • July 27, 2009
                          • 72
                          Joe Ray has done my gauges, wiper motor, headlight motors, radio and clock on every car I’ve done. I’m very specific in what I ask him to do as far as what to refinish vs what to leave original and he has always done them exactly as I’ve asked. Always stands behind his work as well. Jeff
                          • James C.
                            • July 4, 2012
                            • 81
                            Restorations By Karl. Great w/Gauges, Clocks, Wipers, Headlight Motors, etc...
                            Karl F Burl
                            Westminster, MD
                            410-598-2429
                            Does a great job, reasonable rates.
                            Jim C.
                            • James C.
                              • July 4, 2012
                              • 81
                              Sorry typed the wrong phone #.
                              410-596-2429
