steering column ground - NCRS Discussion Boards
  • Howard H.
    • January 10, 2007
    • 142
    How is the steering column grounded on a 70 with tilt? I have no horn or key buzzer, slow signal light flashes. I have disconnected the steering column wiring connector and have determined the horns and key buzzer works. After looking at the wiring diagrams I can't see how the column is actually grounded. Is it through the rag joint bolts?
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: steering column ground
    To "test" the continuity of the rag joint just clip a jumper wire across the bolts of the rag joint. Then test to see if the horn and key buzzer works.
    • Frank D.
      • December 27, 2007
      • 2703
      Yup...or use a multimeter...
      • Howard H.
        • January 10, 2007
        • 142
        OK, thanks, that will be my next thing to check and will let you know if that fixes it.
        • Howard H.
          • January 10, 2007
          • 142
          Rag joint connection good. Took the top of the column apart down to the plastic bushing and plate just above the signal light switch. Turns out one of the contacts was corroded. Cleaned it up and put some electrical grease on it, reassembled and it works. Would like to replace the key buzzer switch but wait and do that later.
