Corbin Clamps - NCRS Discussion Boards
Corbin Clamps
  • Jeff S.
    • February 1, 2005
    • 73
    Corbin Clamps
    I have my original copper radiator going back in my 59. I have not been able to find a set of Corbin clamp pliers that will open the clamp far enough to go on. The AIM says all 58-60 use Corbin clamps. Can anyone steer me in the right direction? TY Jeff
  • Larry M.
    • January 1, 1992
    • 2701
    Re: Corbin Clamps
    Larry
    • Bill S.
      • April 30, 2002
      • 154
      Re: Corbin Clamps
      Are you sure you are using the right size clamp?
      Bill Strobel
      Owner Independent Towing
      Fayetteville, NC
      1979 Corvette White/Red L-82 4 spd
      Only 4,200 miles
      Do It Right or Don't Do It At All
      • Jeff S.
        • February 1, 2005
        • 73
        Re: Corbin Clamps
        No, The correct size is not given anywhere that I can find? I only have what the Corvette distributors sell
        • Bill S.
          • April 30, 2002
          • 154
          Re: Corbin Clamps
          Sounds to me like you have a clamp one size too small. The pliers are engineered to open the correct clamp up the needed distance so that they slip over the sealing ridge and then when the clamp closes it provides the correct tension to seal the hose. What you need is either someone to give you what the correct size clamp is or provide the ID of the correct clamp before the clamp is installed.
          Bill Strobel
          Fayetteville, NC
          Only 4,200 miles
