C2 66 Roadster Center Cushion vinyl cover glue application - NCRS Discussion Boards
  • Bob A.
    • April 1, 2003
    • 172
    Is the glue application shown in the attached photos typical of the way the vinyl was glued to the sheet metal base?
    Thank you!
    Bob
  • Edward D.
    • October 25, 2014
    • 206
    Re: C2 66 Roadster Center Cushion vinyl cover glue application
    Bob, yes they were glued but I don't recall the adhesive being white. I think it was the yellow contact adhesive GM used pretty much everywhere. I had an original 66 armrest here in the shop till last year but sold it to a guy who needed the baseplate (repros apparently don't fit quite right). But as I recall the adhesive was GM yellow (perhaps clear when new) and not white.
    • Bob A.
      • April 1, 2003
      • 172
      Ed:
      Thanks for your reply.
      The area that appears "white" in the photo is actually bare metal. The brown area is the glue. I want to know if the glue was applied to the entire metal base at the factory as pictured. If the brown glue pictured is not a factory application I will strip the brown glue from the entire metal base and only apply the glue to the perimeter of the metal base where the vinyl will attach.
      Bob
      • Russ S.
        • April 30, 1982
        • 2162
        No, It wasn't applied to the entire base.
        • Harry S.
          • July 31, 2002
          • 5299
          From an April 63 Car.
          • Bob A.
            • April 1, 2003
            • 172
            Harry:
            Wow! Thanks for the photo, very helpful.
            Bob
            • Jim D.
              • 2884
              With the exception of a small glue free strip down the middle, my 65 cushion looks exactly like the O.P.'s. I don't know what color the glue was originally but it turned brown at some point.
