body off - NCRS Discussion Boards
body off
  • Mel S.
    • August 31, 1992
    • 264
    body off
    I an taking the body off of my 66 convertible. I have a lift and plan on using this method to do it. With the convertible hatch open, i was going to put a strap from the back side of the body (there is good piece of steel running along the length), build a tripod out of wood that would end above the windshield and strap the other end to the radiator support. I do not want the body to "flex" down which can break the body. I have the strapping from Nolan Adams to do the lifting. Any feed back would be appreciated.
    Mel
  • Gene M.
    • April 1, 1985
    • 4233
    Re: body off
    Should be supported/lifted as the body mounts do with the doors closed.
    From your description it sounds a bit hokey.
    • Tony R.
      • April 19, 2017
      • 201
      • Michael J.
        • January 27, 2009
        • 7167
        Re: body off
        Here is a picture of the rig I am currently using, and have used several times for mine. They were all coupes, but it is just 4 straps on the birdcage edges and I never had any flexing issues.
        • Jim D.
          • 2885
          Re: body off
          I've used my 4 post lift multiple times for removing/installing the bodies on both coupes and convertibles. Install is always done after paint and there's never been a problem. On convertibles, I made a fixtures that bolt to the top hinge and the door striker just to be safe. They're not needed on coupes as the roof structure prevents any possible flexing.
          • Edward B.
            • January 1, 1988
            • 537
            Re: body off
            Thankfully entitled "body off" with nary a reference to "frame off." I'm a bit concerned about lifting with the doors removed. Either leave doors installed and latched or add bracing as shown in Post No. 5.
            • Michael J.
              • January 27, 2009
              • 7167
              Re: body off
              Agreed, I would never lift without the doors installed.
              • Joe R.
                • July 31, 1976
                • 4552
                Re: body off
                Here's a pic of a convertible with the doors off and something to substitute for them not being there. Coupes are easy but converts can be a problem. Doors or not the converts will bow like a green stick so be careful.
                JR
                • Mel S.
                  • August 31, 1992
                  • 264
                  Re: body off
                  Thanks for the hokey reply but it worked
                  • Jeff M.
                    • July 27, 2009
                    • 72
                    Re: body off
                    I used the same exact method that Michael Johnson posted a pic of on my 67 Roadster with no issues at all. I bought the strap ends with the flat hooks as they fit really well over the bottom edge of the birdcage. I extended them as far apart as possible to help with support. I removed and reinstalled the body after restoration using this method with the doors ON the car since mine is a roadster. Good luck and take it slow and easy, Jeff
