Lectric Limited Plug Wires - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 952
    Ten years ago I purchased a set of date coded plug wires for my 66 Convertible. The car ran fine and still does today with these wires. Back in 2011, I received a National Top Flight Award at the Novi National. I purchased a 65 coupe five years ago and also replaced the wire with LL plug wires. The car ran fine for a while and received a Chapter Top Flight award. However, a short time later, it started to miss. I replaced the coil and points/condenser but to no avail. I resistance tested the LL wires and found two to be open. I replace all of the wires with an aftermarket set and the car runs like champ.
    Since I want to drive my 66 more now, I am considering removing the ten year old LL wires and replace them with AC wires.
    PS- I read Mike McCagh's article on solid core vs. stranded wires.
    Dave Kitch
    Chairman Pittsburgh Tri State Chapter
  • David H.
    • June 30, 2001
    • 1545
    Re: Lectric Limited Plug Wires
    Dave Kitch
    Dave
    Don't mess with something that works.
    Dave
    • Dave K.
      • November 1, 1999
      • 952
      Thanks for your opinion.
      • John D.
        • December 1, 1979
        • 5507
        Dave Kitch, If you want to listen to the radio then the good MD's wires are out.
        Look for a set of NOS Delco wires 2987482.. Joe Lucia gave us this number long ago. (I think) John
        • Gene M.
          • April 1, 1985
          • 4232
          Copper wires that are spiral wound should not hamper radio reception and still give good ignition.
          You BBC guys with the shielded wire even works better.
          • Ronald L.
            • October 18, 2009
            • 3248
            Dave I did same that year +/- but those same LL wires caused same issues (new) you noted and old originals went back on.
            • Dave K.
              • November 1, 1999
              • 952
              Thanks for the heads up Ron
              • William B.
                • April 30, 1975
                • 942
                Dave , make it real simple, use Delco D508 wires avaliable at most parts stores that handle Delco parts or on ebay a lot, I have attached a picture of my spare set.
                I use them on small block c1 c2 vettes, picture attached, black wires with orange boots
